Problem
How can i increment one numerical then decrement it. now i crement 30 upto 60 athen it reach 60 to decrement upto 30.
so finaly  i want 30 to 60 to 30 in between rang.
(3,465 Views)
How do you want to increment it? in what step size?
 Or you just want 30, 60 and then again 30 ,60 and so on? Could you be more precise in what you want?
The attached VI produces always values between 30 and 60
Nghtcwrlr
(3,450 Views)
Let me know if you need explanation
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,442 Views)
It does not work. There is no decrementing.
p.s. This sounds like a howework problem and we do not provide questions to homework. Post what you have tried and explain where you are stuck. Do not use locals like the unworking example above.
(3,428 Views)
