Why does CompileWorker crash in LabVIEW FPGA?
I'm currenty working on a simple application using a PXI Chassis running Windows XP with LabVIEW 2012 installed and all appropriate modules for the application as well as a CompactRIO Chassis (cRIO-9075). I developed the project using my office PC (Windows 7) with the same exact software and drivers installed as the PXI Chassis. I was able to generate a bitfile for the FPGA without a hitch and ran a test by deploying the RT Controller VI and passing Shared Variables along using the Host PC.
I brought the CompactRIO and connected it to the PXI Chassis and copied the entire project over to its OS. Upon trying to run and therefore compile the FPGA VI, it generates the intermediate files, opens the Compilation Status window showing the status as "Attempting to Connect to the Local Server". Then, a message pops up saying CompileWorker.exe has to close.
I ended CompileWorker.exe from task manager and tried to open it from its location in C:/program files/National instruments...the same message pops up upon trying to open it.
MAX is showing the CompactRIO and Modules. I tried a COMPLETE reinstall on all of the software/drviers installed on the RT Controller using MAX.
I tried a COMPLETE reinstall of LabVIEW and all of its componens. It seems as though CompileWorker.exe does not want to run on the PXI Chassis.
Would it have anything to do with the fact that I'm developing the prioject on Windows 7 and trying to run the same project on Windows XP? Anything else that could possibly cause CompileWorker.exe to crash?
(2,590 Views)
Hi, you can check that in this post.
Alejandro C. | National Instruments
(2,570 Views)
