Problems Using MAX
Hi, I have a GPIB-USB-B cable. In order to configure it I need to use MAX. The problem is that whenever I open MAX, it restarts my computer whenever I click on anything in the program. Is this a problem with the MAX software or something screwy in my computer.
thanks
ap1150
(2,912 Views)
ap1150,
It sounds like you have some corrupt configuration files. Try deleting your 'Data' directory in ../National Instruments/MAX. Then restart MAX and see if the behavior continues. As a side note you can prevent your machine from auto reboots by going to your System properties (in the control panel). Click on the 'Advanced' tab and uncheck the 'Automatically restart' box. Let me know if this helps!
Craig H.
NI Applications Engineering
(2,893 Views)
The problem with ahs been solved. I had 2 versions of MAX and I uninstalled one of them.
thanks for your help
(2,889 Views)
