Is it possible to use board without MAX
Hi All,
I am develloping an Application that will use a NI USB measurement module. This Application is going to be distributed and used in the production in different industries.
I don't want that an operator can change the channel settings in the MAX, because this could make the measured results worthless. I have heard, that it is possible to controll a board without the MAX under CVI, but LabVIEW needs the MAX. Is it possible to use the dlls that are used with CVI in LabVIEW as well and controll a board without even installing the MAX.
Best Regards
Dermot
Message 1 of 1
(2,309 Views)
