active cursors label's attributes
Since there is no way to set active cursors label's attributes at this point in time, I am looking for an alternate graphing package that will integrate with LabView. I'm thinking of something like Matlab. Are there any other suggetions?
Also, the project consists of building a stand alone executable that will be put on several target machines. In addition to the LV runtime engine will a Matlab runtime engine have to coexist with LV?
Thanks.
(2,760 Views)
@bb Herman wrote:
Since there is no way to set active cursors label's attributes at this point in time...
What do you mean by "no way to set active cursors label's attributes" ?
CC
Chilly Charly    (aka CC)
(2,732 Views)
ProEssentials
I've been using it for several years. Great for print.
-Joe
(2,721 Views)
Thanks for the infor Joe.
Have a very simple question. Using AcitveX and LabVIEW how do you get a graph to appear on the screen or better yet in a report(Word for example)?
(2,707 Views)
It depends on what you are going to use. You can always capture the image of the activex control using the property/method node, save it to a file and then insert it to the file programmetically. If you are going to use ProE, then use the "PEAction" property to export the graph to a image file or even to a printer.
-Joe
p.s. there is no royalty fees for distributing your application when using this tool.
(2,697 Views)
