Showing results forΒ
Search instead forΒ
Did you mean:Β
Problems using command.com /C in system exec
I am attempting to run Hysplit trajectory program from Labview and I am trying to call a executable but I am not having any luck. I have tried the customary command.com /C filename.exe and command.com filenam.exe and have had no luck. Just wondering why this would not be working?
(3,838 Views)
Are actually typing "command.com /C filename.exe" and "command.com filenam.exe" as the executable filename??
Have you tried to simply use the "filename.exe" ?
If so, can you post that portion of your vi or a jpg image?
JLV
(3,810 Views)
We ran into this yesterday as well. A VI that works on XP pro using "cmd /c ..." doesn't work on XP home.
___________________
Try to take over the world!
(3,806 Views)
Hi tst,
So we now add you to the list of Msuff casulties.. ?? πŸ˜‰
I was never impressed by XPee..  and never will..
I wish that Msuff would release something professional for the professionals and a "barbie" version for the kids... and not a mix of the two..
The OS should become more reliable and more robust before adding features.... especially security features that don't work and are more of a nuisance...  not that I dislike XPee or anything of that sort...  πŸ˜‰
πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
Long Live Linux!!!
(3,788 Views)
