Problems when running without block diagram open
Showing the block diagram probably slows down execution just a tad, enough for the code to work, so it's a timing issue somewhere.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 17
(951 Views)
Do you have breakpoints in your code? Maybe in this specific vi?
Also, you might want to run a mass compile in case there is some corruption.
Norbert
Norbert
Expert: Geometry
Message 12 of 17
(940 Views)
On one computer it helped when added a 10ms wait or Control task instead of Start task (with "Commit"). On the other one it didn't but when I open block diagram and/or add probes it works just fine. When using breakpoints it works as well. So I suspect a timing error as well. The two computers both run Windows 7 with LabView 12.0.1f5 installed. They run throught two PXI-rigs, the one that works on a PXI-1044 and the other one on PXI-1042.
I have attached a picture of the message that I get. Hope this helps...
Message 13 of 17
(929 Views)
Forgot to write that the NI-DAQ version is 9.8.0
Message 14 of 17
(927 Views)
Hi Mersad,
Thanks for the information. If you check this folder:
C:\Users\xxxxxxx\Documents\LabVIEW Data\lvfailurelog, where xxxxxxx is your Windows user account, can you find any file related to your crashes? It should be a txt-file with date and time of the crash containing some more info. If so, could you attach this as well?
Otherwise, if this is a timing error, one might try to do an execution trace of the problematic code. To this end, you could download and evaluate (7 days) the NI LabVIEW Desktop Execution Trace Toolkit
You can find more information about DETT here and here.
Message 15 of 17
(917 Views)
Thanks! I will try the trace! These are the report files contained in the report folder.
Message 16 of 17
(911 Views)
For some reason the files weren't attached in my previous post. New try...
Message 17 of 17
(910 Views)
