Rotate header of the table control by 90 degrees.
Is there a possible way to rotate the header of the table control by 90° same like changing the label of any control or indicator  programmatically? Likewise rotating the headers in excel.
Message 1 of 11
(4,378 Views)
Unfortunately, no.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(4,367 Views)
There is no native way to do this, but depending on how much time you want to spend you could probably do this with a combination of an array of picture controls, which move with the table, and lay over top the header to look like it is part of the header.
Message 3 of 11
(4,350 Views)
Something like that?
Those are string controls resized with the background set to transparent and the caption shown rotated and placed over the control body floated over the column headder row.
Not super elegant, but if you need to go there  it can be done
Message 4 of 11
(4,338 Views)
Soon this (and much more) will be possible Smiley Happy
https://twitter.com/rajsite/status/474814384401707008
I build web apps for LabVIEW
http://chrislarson.me
Message 5 of 11
(4,328 Views)
@ ould you please upload the example
Message 6 of 11
(4,311 Views)
Here's an example of what I was thinking.  Of course with an array of picture controls that means all columns would need to be the same width.  Of course if you don't have horizontal scrolling you could get away with fixed images.
Now that I think about it what is wrong with just some string comments on the front panel of the column text doesn't change, and no horizontal scrolling.?
Message 7 of 11
(4,291 Views)
@Hooovahh : Yes, exactly this is my next question Smiley Wink
Message 8 of 11
(4,275 Views)
You can't really get a ref to the comments and set them dynamically or change their possition programatically  But if the headders are static that is a relativly simple implementation.  Right about then the spec will change to make them dynamic
Message 9 of 11
(4,255 Views)
Message 10 of 11
(4,233 Views)
