Output data type of NI 9225
How can I get the output data type of NI 9225 (300V rms module)  module as waveform? By default  it is coming as DBL and other datatype options are disabled.
(2,433 Views)
try something like this.
Simyfren
(2,412 Views)
The DAQmx read function is polymorphic.  Right click and select Type then choose Single Channel Multisample waveform.  Post your code if you can.  If you are using the DAQ Assistant configure the from dynamic data type to be a waveform.
(2,399 Views)
