XML data type problem
I am trying to unflatten data from an xml file but my input type for the type on the unflatten I believe is invalid and I am getting error 1106.
Attached is the xml file and VI
XML file is in text due to upload constraints
I have not lost my mind, it's backed up on a disk somewhere
(3,869 Views)
Accepted by topic author PauldePaor
Your data type cluster does not match your XML file. Fixed VI (LV version 2013) is attached. However, the file you posted appears to be a single element, not the entire file, so I cannot verify it works.
If you have an earlier version of LabVIEW, the cluster was missing a timestamp and had a cluster at the end which should have been a string.
Duplicate post from here.
(3,847 Views)
Hi DFGray
Thanks for your reply, I cut that test file out of the full file just for testing purposes.
I have attached the full file below
(3,838 Views)
