08-24-2011 02:31 PM - edited 08-24-2011 02:31 PM
Dear,
I've seen a couple off old toppics about this LLB. LLB i use
See the attachement, mine OID dont get translated the rightway.
The problem is that mine OID has a number of 30 bits, 852179988, RRS04v30. That is split in two, a b11 and then the rest of the number.
But how to solve it i don't know. If someoneelse has a better LLB for SNMP communication of knows a solution for mine problem,
Thank you
Solved! Go to Solution.
08-24-2011 02:36 PM
It's not appropriate to post a bmp file renamed as jpg to get around the ban. Do you think renaming a file will actually change the format?
08-24-2011 03:54 PM
Sorry therefor
It was a printsceen in XP, now is it a real JPG
08-25-2011 01:13 AM
Already solved it, the fix is put the input of SNMP Encode SubID.vi in SNMP Build OID.vi on U64.
Then even this OID got the rightway translated:
.1.3.6.1.4.1.7829.1.852177940.322961408.1.1.3.0
Hope it's help for someone else![]()
