Problems with Database Connectivity Toolkit and LV 7.x
I am using ver1.0.1 version of the Database Connectivity Toolset along with LV 7.0 and 7.1.
The issue are the LV7 library time vi's. The LV7 versions of the "Get Date/Time in Seconds" now returns a time stamp instead of simply seconds as it use to. Since I need to connect to a Database Toolkit vi "DB Tools Format Datetime STr VI" that needs the old seconds value, I am stuck. I don't see a conversion for time stamp to seconds (although a conversion for the other direction exists). I suppose I can try and make this calulation, but it is a PIA.
Is there an update to the Database toolkit to handle LV 7?
(2,595 Views)
I guess I figured out a kludge. It turns out that the Database VI I was refering to can be easily modified to avoid the "seconds since 1904" issue. In this way I can get my time in.
(2,592 Views)
> along with LV 7.0 and 7.1.<br><br>The issue are the LV7 library
It is much simpler than that! Just use a Conversion node to convert the
timestamp to a DBL precision or uInt32 value. Those conversion nodes
know how to handle timestamps.
If you load an older VI into LabVIEW 7.x the load operation should
automatically insert a conversion function. Since it apparently didn't
just do it yourself.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,572 Views)
