problem when executing the same subVI in parallel.
Hey!
I have created a subVI that I am using in two applications that executes in parallel. For some reason the applications is using the same instance of the subVI, which creates conflicts when the applications are trying to use the same subVI at the same time. Is it possible to solve this problem?
/Jakob
(3,166 Views)
If you run the subvi in reentrant execution, it will use another instance of it everytime it runs.
Right click on the icon on the subvi window top right and then choose - execution - reentrant execution.
Hope it helps.
Paulo
(3,162 Views)
Open the SubVI and go to File>>VI Properties. Select Execution and check "Make VI reentrant". This should solve your problem. You should read more about reentant VIs and how they work in the site. They have different kind of uses.
___________________
Try to take over the world!
(3,161 Views)
