Producer/Consumer or Master/Slave for Acquiring, Control, Analysis, and Record Data
Thank you very much .aCe.. I have just found a chance to try RavensFan's suggestion. And it works as I intended. Thank you RavensFan. I know the forum rules aCe, you do not need to remind me. And also thank you again for directing me a really good example. I attached the VI snippet that includes RavensFan's suggestion.
Egemen
Message 11 of 13
(916 Views)
I am sure you do. However, you still havent given him any kudos (not until this post anyway).
I am not trying to tell you anything. Eventhough you have commented thanks and appreciated his help (which is very good of you) it will stay in this particular post.
Kudos on the other hand adds to the statistics, so the more the kudos the better the reputation. So when you or me come to look at a post in the future you can just look at his/her kudo count and can be rest assured that he/she knows what they are talking about. That is the least you can do to someone who has put in some time to help you in my book.
Also you have marked your own post as the solution, eventhough you admit that RavensFan 's post was the solution for you.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 12 of 13
(911 Views)
Firstly, I have selected my post wrongly as an answer, I corrected it. Thank you for warning me. I know what the kudos are and you could not determine who I would give kudos. Thank you.
Egemen
Message 13 of 13
(899 Views)
