03-28-2012 01:20 PM
When I run the Profile Performance and Memory tool on my project, I get very large numbers for VI Time (and Sub VIs Time and Total Time) for some VIs. For example 1844674407370752.5. I have selected only 'Timing statistics' and 'Timing details'. Sometimes the numbers start with reasonable values, then when updating the display with the snapshot button they might get large and stay large. Other VI Times remain reasonable.
LabVIEW 2011 Version 11.0 (32-bit). Windows 7.
What gives?
- les
03-29-2012 11:45 AM
les,
the number indicates some kind of overroll.... so, do you have a vi where this happens all the time? Can you share this with us?
thanks,
Norbert
03-29-2012 12:27 PM
I've not used profiling much and the project I'm using it on has some 200 VIs. I did run it on a 3 or 4 VI project and it worked fine there.
03-29-2012 01:50 PM
This is a bug in LabVIEW 2011. We're tracking it in CAR #298125. Unfortunately, there's not a workaround except to use LabVIEW 2010. I hope this won't hold you up too significantly.
