Profile Performance and memory
Hi, guys
I am trying to analysis my Profile Data for the Profile Performance and memory.
When I check the data for VI Time, I found there are same VIs with different VI Time, what is that mean
The reason why I am doing this is because I am going to add pulse model for my VI, so I need to know the relationship between my all instruments and time, Am I in the right track
(3,663 Views)
Accepted by topic author huskerli
It looks like the timing had a resolution of 15.6 ms, which I think is common on some flavors of the Windows OS.  Note that the average times on some of those VIs is zero.  This suggessts that for many of the 1878 runs the time was probably recorded as zero and a few were at 15.6 ms.
This is one of the limitations of the Profiler.
Lynn
(3,644 Views)
Thanks johnsold
I am now understood the resolution maybe a problem.
But I am still not sure my original question which is why they I had some vi with different VI time
BTW, the one named NGEL_Corr_ST2013_Caption.vi is my main code at.
(3,635 Views)
