07-07-2008 08:40 AM
07-08-2008
03:46 AM
- last edited on
11-03-2026
04:09 PM
by
Content Cleaner
Mark,
I would suggest you reinstall the DAQmx drivers. You can get the most recent version from our website at: https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
I hope this helps,
07-13-2008 12:15 PM
07-15-2008
01:54 AM
- last edited on
11-03-2026
04:10 PM
by
Content Cleaner
The Data Acquisition palette relies upon two installations: the LabVIEW installation and the DAQ driver installation. When the NI-DAQ drivers are installed, the installer will automatically detect the versions of LabVIEW present on the computer. Most often, the DAQ support for these versions of LabVIEW are then installed. Unfortunately, this means that if you upgrade to a newer version of LabVIEW you will need to add DAQ support for your newer version of LabVIEW by modifying/reinstalling your DAQ drivers.
Steps to ensure driver VIs appear in LabVIEW:
Steps to add driver VIs if LabVIEW is installed after the NI-DAQ drivers:
Verify that the proper menu files have in fact been installed correctly:
If this doesn't work then please let me know your DAQmx driver version installed on your system (from Measurement & Automation > Software > NI-DAQmx)
All the best,
07-15-2008
02:08 AM
- last edited on
11-03-2026
04:10 PM
by
Content Cleaner
In addition to this, if it is just the DAQ Assistant you are missing (and you have the DAQmx VI's) then this is an issue that has been put forward as a Corrective Action Request #118737 for 8.7.1f2 from the December Developer Suite. If you have been caught up in this then please download the latest NI-DAQmx driver from here which should solve the issue for you by installing 8.7.1f3.
All the best,
10-09-2011 09:52 PM
I'm having the same problem with LabVIEW where my DAQ Assistant icon is not showing up in the Functions Palette.
I tried everything you have suggested but still nothing...
Any ideas?
Thank you.
02-05-2012 09:07 PM
I'm having the same problem here. I have try all the drivers that have been listed above. But still can't find the icon.
Anyway, I'm using trial version of LabVIEW 2011
Tq.
02-05-2012 09:09 PM
Tq.
02-05-2012 09:19 PM
07-25-2013 01:31 PM
I've got new DAQ-MX drivers and only Labview 8.5. I assume I'll need an older DAQmx to make this work.
