Profinet interface using the Hilscher CIFX 70E or CIFX 50E boards
Hello
Did your issue resolve? Could you share the solution?
Message 11 of 13
(513 Views)
https://forums.ni.com/t5/LabVIEW/How-to-add-GetValueByPointer-XNode-in-LabVIEW-Application/td-p/4226...
 Check this link i think you get error in getvaluepointer.xnode  replace the xnode vi with getvalue bypointer.vi which is available in the above link
Message 12 of 13
(390 Views)
