Program Running in VI but not in build
Hi Everyone,
In my VI, my program is running fine.  I am able to control an LXI XG 600-2.6 DC power supply through the LAN.  My program specifies a voltage to output and it measures the voltage current.  It can also update the voltage as well and turn it off.
However, if I run the program in my build, it will do all of the above accept update the voltage.  I've built the executable with the debugger, and as far as I can tell, all the commands are being sent to power supply during the update state.
Has anyone else had similar problem to this, or have any suggestions?
Message 1 of 8
(3,536 Views)
That is only the project file, which contains all the information about the LabVIEW project, but not the files, themselves.  Please include all the files associated with the project in a zip file.
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(3,518 Views)
There are many possibilities for why the executable would be behaving differently. Some common ones are that you have a control (especially in a SubVI) that you had set to something but it was not "set as default". When built into the executable it will pop back to the default value. Also, sometimes there is a relative file path which is now incorrect because your executable is in a different location relative to that file.
Message 3 of 8
(3,505 Views)
Oops, I didn't realize it would do that.  Here they are attached now.
Message 4 of 8
(3,442 Views)
You may wish to remove the breakpoint in the update state before you build the executable.
Just a thought- but you might try thatSmiley Wink
Message 5 of 8
(3,432 Views)
Haha oh, I've removed it and that didn't fix anything
Message 6 of 8
(3,429 Views)
It's like it is "ignoring" the OUTput ON; command in the update state.  I tried turning the output off in this state, but it didn't either.  I don't understand why this only happens in the build...
Message 7 of 8
(3,419 Views)
Your "VISA resource name" is empty, when is that supposed to be populated?
Message 8 of 8
(3,403 Views)
