Program not working with windows 7
I developed a small application and builted in windows 7 2011 version.
When i runned this app from start menu, this application is not running correctly in windows 7. but when i installed this application in another pc which has windows xp this is working perfectly .
For the below attached project, In windows 7 this application is not generating the supporting file "list " ,  when i runned from start menu. But When i runned the application where it is builted in windows 7 also this is working .
Help me in solving this problem
Message 1 of 12
(4,072 Views)
Here are the attachments
Message 2 of 12
(4,068 Views)
First, read this: http://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363
Second, there are specific permissions differences between Windows 7 and Windows XP. Windows 7 will not allow you to write to certain directories unless you are running as an administrator.
Third, what is your VI supposed to do? It seems to be to two completely different VIs merged into one.
Message 3 of 12
(4,053 Views)
Thank u
Message 4 of 12
(4,044 Views)
Your issue has nothing to do with Windows 7. Your issue has to do with the fact that you use "open or create" for the Open dialog. If the file already exists, then you will get an error. You need to use "replace or create".
Message 5 of 12
(4,040 Views)
Hello
Message 6 of 12
(4,013 Views)
Accepted by topic author Nagaa
Hi Nagaa,
did you read MS recommendations for writing "good" software? NEVER write data files in the program directory!
Win7 might block this even when your app has admin priviledges...
Message 7 of 12
(3,998 Views)
No , i hav,nt read MS recommendations for writing "good" software . can i have the link plase ?
Message 8 of 12
(3,991 Views)
Hi Nagaa,
dig into MSDN on your own...
Message 9 of 12
(3,989 Views)
@Nagaa wrote:
Hello @smercurio_fc
And you did not get my point. Your program will STILL create an error even in Windows XP if you run it a second time giving it the same directory name. The fact that you are writing to the Program Files directory is a Windows-7 specific issue, as I pointed out in my first response.
Message 10 of 12
(3,967 Views)
