configure model name in visa
Hi All,
This probably really simple but I'm getting stuck.
I want to write the model name programmatically, (not using MAX), onto a VISA resource but I can't change the property model name to write.  Does anyone know how I can do this, see attached?
Sean
(2,863 Views)
Accepted by topic author SeanJ
Hi Sean,
I don't think this is possible, why do you need to change the model name? There might be another way of performing the functionality you're after.
Kind Regards,
Joel G
National Instruments UK & Ireland
(2,837 Views)
My guess is that he probably wants to present a user-friendly menu with instrument model names, rather than just the default VISA Resource Name. In this case, I'd suggest using aliases.
(2,833 Views)
Hi Joel/smercurio,
I just wanted to insert a type in a legacy driver so that I could switch easily between devices.  It looks like you are right, it can't be done programmatically.
I gave up and used a type def.  Thanks for your help.
Sean
(2,826 Views)
