Programatically Changing Com Ports
I need to programatically change the COM port within LabView.
I am writing a program for clients and need to save the COM port settings within an exicutable. I was going to atchieve this by writing to an ini file. I cannot directly save the VISA variable but can save the following properties.
Intf Inst Name
Intf Type
Intf  Num
The problem is I cannot write to these properties on the initialization state of the program. Is there a way I can save which COM port was being used from one session to another of an exe? Thanks in advance for all your help.
Jesse
(3,086 Views)
Hi Jesse,
you can store it as a string. If you read the string from a file you can directly connect it as a com port selection. It also works if you typecast the string to the com Port type.
Mike
(3,080 Views)
