bar graph
I created a small VI. I need to plot a bar graph, like I did in excel. See examples. In labview I get a line as graph or a blocked line between the point. I want a start line at the zero and go up to the Y value. The x value in this sample is 0,1,2,..,10. But in real time it can be also values like 0.2,0.4,0.6,..,20.0
Is there a possibility for this?
best regards,
Rens
(14,308 Views)
Well, you actually need to select a bar graph. Click on the legend to select the plot type.
Message Edited by smercurio_fc on 04-16-2010 12:47 PM
(14,298 Views)
There's a post here that addresses this.
Jim
(14,293 Views)
Accepted by topic author RvG
and if you want to get fancy with the labeling see here.
Ben
(14,292 Views)
