Programatically customize a control
@Hooovahh wrote:
@tst wrote:
I don't think I ever tried this, but it might be relevant:
https://lavag.org/topic/20145-vector-boolean-creator/
Thanks for the shoutout. Yes under the hood it uses the same LabVIEW functions replacing sections of the control file with a new vector image so it scales better.  I have updated that example since that post to use native 2D picture controls instead of a Windows explorer search, and added the Google Material icons but I didn't want to post it unless I thought it was ready since it is a somewhat large attachment.
Unfortunately, on LAVAG, your code is
Can you repost it?
Message 11 of 17
(1,942 Views)
Can you repost it?
I can access it and download it. Are you logged in on LavaG?
Rolf Kalbermatter  My Blog
Message 12 of 17
(1,938 Views)
Can you repost it?
Oops.  That was the problem.  I wasn't logged in (normally login is auto, so I don't think about it).
Message 13 of 17
(1,928 Views)
Hi Hooovahh,
Please tell me about this class specifier constant:
How did you create it?
Can you create other special reference constants?
Message 14 of 17
(1,926 Views)
Hi Hooovahh,
Using the ctrl+b Quick Drop:
Drop a Class Specifier Constant on the BD > Select it > ctrl+space > type "VI" > ctrl+b.
This also works for "Application".
Programmatically:
Invoke method "Set Type" of class "ClassSpecifierConstant".
You can either specify the class by its unique ID string or by its name (for this you need to set parameter "AllowAltName" to True).
Raphaël.
Message 15 of 17
(1,913 Views)
I don't want to derail the thread more, but this got me motivated to post an update to my Boolean Vector Control utility.  So I cleaned it up and posted it over on VIPM.IO
https://www.vipm.io/package/hooovahh_boolean_vector_controls/
Install the package and its dependencies and you'll have a Tools >> Hooovahh >> Boolean Control Creation...  Once ran it will start trying to display all the icons the toolkit installed.  I'll update the LAVA thread with more details.
Message 16 of 17
(1,897 Views)
Hi Hooovahh,
Programmatically:
Raphaël.
But apparently no way to do it with a mouse?
Message 17 of 17
(1,875 Views)
