Programaticaly inserting block into block diagram.
Hi Andoro,
if you need to connect your inputs with different logic, then maybe this thread helps.
https://forums.ni.com/t5/Digital-I-O/Digital-Input-check-and-conditional-function/m-p/686159/page/2?...
Mike
Message 11 of 17
(1,325 Views)
Wow...what a quick response...thank you Mike!! Smiley Happy
Let's see if this approach can get me closer to my goal.
Message 12 of 17
(1,323 Views)
After seeing the figure (which appears now), this question seems to be the same as this one.
Message 13 of 17
(1,299 Views)
Yes...it is the same problem but i would like to do this programaticaly.
So...the pictures that i've posted are 2 examples of ladder diagram.
The last picture shows a function that is specific to ladder diagrams in the sense that i can use a auxiliary contact from the relay to complete the main logic equation.
I am working on a example and i will post it next week.
Hopefuly this would shed some light on the issue at hand.
Thank you !  :smileyhappy:
Message 14 of 17
(1,294 Views)
Please do not create 2 different threads under 2 different user names asking the same exact question.
Message 15 of 17
(1,289 Views)
Hello smercurio_fc !
You got me wrong.... this thread is different from the other because:
1. This is the only thread started by me concerning this problem.
2. I am asking a different question.  The example may  be the same as it is in that post but i'm proposing a more global approach to solving this kind of problems.
I hope that next week i can post an example so you can see what i really mean.
Have a good weekend !
Message 16 of 17
(1,266 Views)
OK. Sorry, I thought you had just created a new username and posted the same question under the new username. It's been known to happen. Smiley Wink
Message 17 of 17
(1,262 Views)
