Programmable plot names in chart did not located in proper position.
I troubled to deal with programmable plot names in waveform chart.
I have 8 signals in a loop and plot names would be generated in run mode.
Problem is... the name of "Plot 0" appeared at "Plot 7". Could anyone help me to understand what happen in my code?
(2,941 Views)
Accepted by jmk_sup
Hi jmk,
this is a very typical error of the (unexperienced) programmer: you need to select the ActivePlot first, then set the properties of that plot!
(Hint: in a property node the properties are executed from top to bottom…)
(2,930 Views)
Thank you!
I did not think of calculation order. 😮
(2,922 Views)
