Programmatic generation of PDF
I need to generate a PDF as report output and would prefer to print a vi front panel directly to PDF as opposed to using a template in (office, etc.).  I need to control deployment cost and would prefer to avoid add-ons.   Does anyone have experience with this?
Message 1 of 10
(4,301 Views)
Here (answers 3 and 4).
Message 2 of 10
(4,295 Views)
I already reviewed the cited solutions and concluded that they do not print the front panel of a vi, but rather work from a template-like interface.  Did I miss something?
Message 3 of 10
(4,273 Views)
For the Simplicity AI LabView toolkit:
Key Features
• String Text to PDF
• Embedded Data Tables
• Headers and Footers
• Embedded Graphics
• Add Front Panel and Control Images
• Multiple Font Support
• 2 Example VIs Included
• Watermark Free
• VI documentation and Help File
For the PDF Report with iTextSharp", take a look at the page 8 of the User manual.  The image of the front panel was added with "Append Front Panel Image.vi"
In both cases it is not a a template-like interface.
Message 4 of 10
(4,262 Views)
Accepted by TCB
In both cases the front panel image is added with the invoke node "FP.Get Image".
Message 5 of 10
(4,254 Views)
Thanks J-M, the solution works great.  For future reference, are the manual and examples available in English?
Message 6 of 10
(4,242 Views)
I work on a new version.  I added some VIs for table formatting: merge cells, image in table, ...  It is working but I am not satisfied - not really intuitive.  I also added some Vis for barcodes .  I plan to have examples in English and of course the user manual with the new version.
Message 7 of 10
(4,215 Views)
You only need those three VIs.
Message 8 of 10
(4,180 Views)
BTW, did you ever get an answer...manual in English?
I need to try using the ITEXTSHARP.  I was using Simplicity and everything was simple and worked great running VI on develoment machine, but for some unknown reason I a compiled, executable version didn't work even on development machine.
I am out of town and don't have access to Labview at the moment.  Do you know if the ITEST VIs have UNLOCKED blocked diagrams.
Thanks in advance!
Shannon F
Message 9 of 10
(4,092 Views)
Hello Shannon!
I recommend starting a new thread for these questions.  You might get a faster response from the community.
Have a great Monday!
Michael B.
Applications Engineer
Message 10 of 10
(4,035 Views)
