Programmatically accessing the Start Menu user display name in XP
Is there a way to programmatically get the name that is displayed at the top of the start menu in windows xp?  I am not looking for the login username, but rather the displayed named.  The computers do not log into a domain and there is not an active directory server.
John
(4,436 Views)
Try the attached VIs.
- Partha ( CLD until Oct 2027 🙂 )
(4,419 Views)
Hi Partha,
on my WinXP both vis gave my logon name (but I'm logged on to a domain...).
Ever tried to program without massive use of locals and frames? Smiley Very Happy
(4,403 Views)
Thanks for your responses.  Unfortunately, I am looking to get the display name and not the user name.  So, on my machine the user name is something like "f-lastname" and the display name is "Firstname Lastname."  The display name is shown at the top of the startbar and also in Control Panel->User Accounts.
John
(4,385 Views)
I'm not sure how the calls will differ between getting the User Name and the Display Name but this Developer Zone Example Program should provide you with a good start. It contains methods for programmatically obtaining user information for purposes of setting access privileges in a VI.
Cheers,
Emilie K. | Applications Engineer | National Instruments
(4,333 Views)
Thanks for all the help.  I was able to access the information using a WMI query.  I have attached the vi that does it.  It uses .net 2.0.
John
(4,328 Views)
