Problem in recognizing DAQmx devices
I am using NI PXI 6251 and 6509 with NI PXI 1042.I was not able to see the DAQmx devices section in the MAX.so how can i communicate with these cards?
In MAX
Under Devices and Interfaces  there are two sections  PXI system and PXI bridge (PXI MXI 4)
In PXI bridge section I can see Chassis 1(PXI 1042). when this is selected the device status is "MXI 4 connection to this chassis timed out".Please help for correcting this problem.I also want to get the cards under DAQmx  devices section
Thanks a lot
(3,805 Views)
Is your chassis turned on before the PC is turned on?
André
André (CLA, CLED)
(3,793 Views)
And hope you ahve puth PXI MXI 4 card in the appropriate slot
See if this Link helps you
(3,782 Views)
And I hope you have put the PXI MXI 4 card in the appropriate slot
(3,781 Views)
Techiess,
Thank you for contacting National Instruments.
Do you have the current DAQmx driver installed on your computer? If you don't or are unsure, you are able to download the latest DAQmx driver. Please look through the DAQ Getting Started Guide, which walks through the installation of the PXI device. Also step through the Configuring Your PXI System in MAX 3.x and Above, which steps through the configuration of the PXI System in Measurement & Automation. The previously referenced link MXI-3 and MXI-4 Troubleshooting Guide, is another great reference to walk through troubleshooting your MXI-4.
If none of these suggestions solve the issue, please send me a screen shot of the Device Manager, with the appropriate device fields expanded, and Measurement & Automation with the device fields expanded.
Thank you very much.
Sarah S.
Applications Engineering
(3,740 Views)
