Programmatically change primary and secondary Y-Axis range
Ok, so the idea is that I have a chart with two different data types on it.  One is plotted on the primary Y-axis on the left side and the other is on the secondary Y-axis on the right side.  Both share the same X-axis.
How do I change the range seperately for the primary Y-axis and secondary Y-axis?  Whats currently happening is no matter which "Active Plot" or "Y-Axis Index" I select, it only changes the range for the secondary axis.  Any help would be amazing!
(4,782 Views)
We are going to need to see some code to help with this.  and some clarification sinc a "Chart" cannot have multiple y axes
Assuming you have an XY Graph this little code demonstrates how to set the scales min and max programatically
(4,772 Views)
This is what I was looking for.  For a few hours I was trying to do this with the properties "Active Plot" and "Y axis Index".  Thanks to you I now know about "Active Y Scale"
(4,760 Views)
I would not like to be boring here... but a chart CAN have multiple Y scales...
Right click on first scale >> duplicate scale
Smiley Wink
(4,706 Views)
