Programmatically changing page color in a tab control
As best I can tell, you can change colors of individual pages in a Tab Control manually (if you have the Allow Multiple Colors property set True), but you can't do so programmatically.
For my particular application there is only one page color I need to change, so I can get the effect by setting up the colors I want manually and toggling Allow Multiple Colors on the Tab Control as needed, but I'm wondering if there is a better solution out there.
Kyle
CLD using LV, DSC 8.5-2009, RT 8.5
Ghoti!
(7,841 Views)
Accepted by topic author Kyle Smith
Sure you can:
Not sure whether you're trying to change the background or foreground color.
Message Edited by smercurio_fc on 01-23-2009 11:41 AM
(7,835 Views)
Kyle
You can programmatically change the individual page colors.
First get the  pages references, select the page you want to change then using the page color property change the color.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(7,832 Views)
Thank you both. I hadn't known how to pull out individual page references. D'oh.
Kyle
Ghoti!
(7,825 Views)
