Programmatically clear array on front panel
Hi, I have a 2D array of data that I'd like to clear immediately after the user clicks 'run.'
One solution I came across seems like it's exactly what I need, only it doesn't seem to translate for LabVIEW NXG.  I'm referring to the 'clear indicators when called' option under the execution page in VI properties.  Is there an equivalent option for NXG?
I've attached an image of the window that appears when I go to VI properties.  It's very minimal.  The options in the dropdown are 'stateless' and 'stateful.'
Thanks for your help!
(4,370 Views)
I don't use NXG, but apparently you can write to a "duplicate terminal" at the start of your program.
http://www.ni.com/documentation/en/labview/latest/prog-elements/dataflow-duplicates/
(4,339 Views)
Two options:
(4,307 Views)
Just update the Array with Default Values(Empty Array) as soon as run Button is Clicked, Hope same works for LabVIEW NXG.
(4,303 Views)
Thank you all for your help! I went with the property node and it works like a charm.
(4,282 Views)
