Programmatically filter array elements containing physical channels as controllers.
I have an array containing list of physical channel controllers. I want to filter the physical channels based in user inputs. For Ex: If the user selects Device 1, the physical channels should only display channels connecting to device 1. Currently the phsical channel array just displays all physical channels available. Is there a way to filter physical channels based on the selected device.
Labview Learner
(3,443 Views)
Use a FOR loop with a Search/Split String.  The "offset of match" will be -1 if the item was not found.  So use a conditional autoindexing tunnel to only include the items that were found (index >= 0).
(3,437 Views)
I see that you have filtered out the channels based on Device selection, but I need the filetered out channels to be controllers, not indicators.
Users should be able to select custom channels from the filtered out list.
Labview Learner
(3,431 Views)
That's the hard way TimSmiley Wink
(3,426 Views)
