Programmatically moving of cursor is slow when XY graph contains data
Does anyone have a solution to the following issue (at least in LV8.5). When a chart contains about 400k datapoints programmatically changing the cursor becomes very slow (100msec). Even on a quad-core 2GHz machine (all in UI-thread?).
The attached file is an example of the issue. I would like to synchronise cursors in multiple graphs. Moving the cursor using the mouse gives response times <<1msec. When you clear the chart (remove data) the speed by setting is also normal.
Defer panel updates or disabling the graph doesn't change a thing. I did not see this item on the bug-fix list of 8.5.1. It seems that the whole graph is redrawn or something...
Kind regards,
Mark Beuvink
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
(3,886 Views)
Anytime you update the graph (including the cursor, or something independant of the graph, but overlaying the graph) the graph will be redrawn...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,874 Views)
