the same waveform shows on two independent VIs which are running simultaneously?
Hi, I am a newbie of LV.
My computer has two monitors. I am going to run two VIs simultaneously on this computer. One VI window will show on monitor 1 and the other VI shows on monitor 2. The two VIs have totally different looking, but they will show the same waveforms. Is it doable?
(2,654 Views)
Yes. Via many many many different methods.
Look into shared variables in the help section.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,649 Views)
Can anyboday provide sample VIs?
(2,635 Views)
Use the LabVIEW example finder in Help->Find Examples and search for shared variables.
(2,616 Views)
