Programmatically setting text justification in a table
I am looking for a method to programmatically set text justification in a table. As far as I can tell the attribute is not available at run time. Has anyone had any experience with this? Thanks.
(3,104 Views)
You are right : there is presently no way to programmatically change the cell justification or font attributes.
CC
Chilly Charly    (aka CC)
(3,086 Views)
Of course you could make several identical tables on top of each other, but with different font alignment, then make the desired one visible ;). It's ugly but will work just fine.
(3,083 Views)
