Ring Control Property nodes color
How do I change the background color for a ring control using a property node?!?! I can change the color of the square around the text but, not the rest of the button. Any ideas?
(3,170 Views)
You can't !!!
That's a curious limitation of the actual LV version, common to most 3D objects. There is a workaround : set the ring background color to invisible with the paint brush. Create a decoration, and place it UNDER the ring control. Then change the decoration color programmatically. See the attached vi...
CC
Chilly Charly    (aka CC)
(3,158 Views)
