Programmatically start rename of tree item
Hi all,
I want to replicate the behavior seen in many tree controls/list boxes. For example in the LabVIEW project you can right-click on an object and select "rename" or press F2 and the text of the item will be highlighted ready for the user to type a new entry.
I can populate the shortcut menu etc. but I can not find how to programmatically initiate the edit operation, any ideas? Simulating a mouse down event with a DLL call seems a bit hacky.
Steve.
(2,902 Views)
Accepted by St3ve
Hi St3ve,
You should be able to achieve this with the tree EditPos Property - as mentioned in the help be sure to set keyfocus first.
Tom L.
(2,894 Views)
Tom,
Thanks for that, I had tried that but missed the bit about key focus! RTFM!
Many thanks,
Steve.
(2,887 Views)
No problem- that one's definitely easy to miss. Robot Very Happy
Tom L.
(2,883 Views)
