Project Explorer "Rename" bug (or feature?)
Not sure what is going on but in a nutshell, I can't rename some VIs in a project permanently. By this I mean that I can transiently rename them, but they eventually revert to their original name.
Let's start with a snapshot of the project content:
Notice the selected VI. It has a small "s" variable name in it. I'd like it to be capital S like all other VIs. Also take a look at the VI called J(S, ) PDF.vi below it. The letter is capital S.
Now I right-click the selected VI and chose: Rename
I get an Explorer dialog window where I change the name to "J(S, ) Normalization Factor [Sum].vi" and after the following warning dialog:
I press OK and contemplate with satisfaction the new project explorer window:
Amazing feats of modern technology!
But wait! What about J(s, ) PDF.vi? Why has it switched to a small "s"?
After almost 20 years of LV, I have stopped asking questions like this, so I just go ahead and am about to rename it to J(S, ) PDF.vi...but hold on a second... What the????
Here is my Project Explorer window:
The Normalization VI has reverted its name to small "s"!!!
I have tried everything, there is no way I can rename those VIs from the Project Explorer.
For what this is worth, PDF is a subVI of Normalization. But why would it matter?
Message 1 of 11
(5,114 Views)
I don't see any OK button...
What if you rename it from the files view (second tab)? Does that work better?
Message 2 of 11
(5,106 Views)
Oopss. Obviously I am using LV 2012... There must have been a typo in that folder name ;-(
Message 3 of 11
(5,098 Views)
 There is none. The correct action is to press "Yes" (the explorer doesn't distinguish between cases).
 I tried that and interestingly, the change is reflected in the "Items" Tab but not in the "Files" one...
 But if I try to then rename the second VI of the pair, the reversion behavior I described is reproduced...
 Therefore I stand by my report.
Message 4 of 11
(5,094 Views)
How about if you first rename it to something that Windows does NOT cosnider to be the same file (e.g., J(Ss...)) and then rname it to what you want (i.e., J(S...))?  I think it has more to do with Windows filenaming than LabVIEW.
Bill
CLD
(Mid-Level minion.)
Message 5 of 11
(5,084 Views)
That is a workaround and that's perfectly fine, but my point was to inform whomever it may concern that there is a bug in the system.
Message 6 of 11
(5,074 Views)
It's certainly very weird, and has something to do with the fact that LabVIEW is really creating a copy of the file and updating all the pointers.  Using the same file name seems to upset it.  I have to say that it is certainly a bug.
Bill
CLD
(Mid-Level minion.)
Message 7 of 11
(5,068 Views)
I'd say it's a windows feature, it's been that way since they introduced long filenames in fat32. Rename in 2 steps, first remove the 's', then add it as a capital.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 11
(5,054 Views)
/Y
I would agree it's part of the answer, but why would it go rename a subVI, too?
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(5,036 Views)
Good question, but it seems it's still using the 8.3 name standard under the hood, in which there's no case sensitivity. I'd say that's the root of the issue.
/Y
Qestit Systems
Message 10 of 11
(5,034 Views)
