Project Template Customization | Capturing the 'Finish' button click event from the NewProjectDialog.vi
We have created a project template in LabVIEW. I need to show a pop-up when the user clicks on 'Finish' in the create project dialog after configuring his project, saying that "the project is getting created". I have already used 'AfterPage2NoUI' to run the PostCopyScripting.vi.
Is there a way to run the pop-up.vi immediately on the click of the 'Finish' Button. Is there any event generated that is only specific for 'Finish' button (that is not common to cancel and back button click). There is a user event 'Quit' generated but that is common for cancel and finish.
Message 1 of 9
(3,545 Views)
Accepted by NikithaSairam
Not exactly sure in what context you want do this.
The wizard window is just a VI, "ProjectWizard Host.vi". So you can (dynamically) start a VI, that watches VI Activation events. You do need scripting options enabled for that event to show. When it get's such an event, check if the VI that's activated is "ProjectWizard Host.vi". If so, open a reference to that VI. Make sure to wire VIAppRef to the application reference input of Open VI Reference.
Once you have the VI's reference, you can dynamically register for value change events of all the controls on the VI, including Finish (I presume, but Next, Back, Cancel and Help worked).
Something like the attached VI. Run before entering the wizard. You might just get a popup when you press Finish... Build in 2013, so things might have changed...
Message 2 of 9
(3,520 Views)
When you make your SpecPage class for your custom page, inherit from the following class:
resource\dialog\NewProjectWizard\SpecPage\ConfirmQuitSpecPage\ConfirmQuitSpecPage.lvclass
This gives you access to override the "Fire Quit Event" VI, which fires whenever the Finish button is clicked.
Message 3 of 9
(3,513 Views)
Thanks for your reply. But I need to capture the event in my spec page that runs only after the project wizard is launched. Is there a way to capture it in spec page.vi?
Message 4 of 9
(3,491 Views)
The fire quit event seems to be trigggered even when cancel is pressed.
Message 5 of 9
(3,489 Views)
That could be. The Cancel might send a value (signaling) to the finish. E.g. Cancel would dismiss changes, then call finish to continue as finish would...
You'd have to catch both Finish and Cancel, and if Cancel is pressed first, take appropriate actions.
Message 6 of 9
(3,481 Views)
If you click Finish, then the 'Force Quit' input of the Fire Quit Event.vi will be FALSE.
If you click Cancel, then the 'Force Quit' input of the Fire Quit Event.vi will be TRUE.
Hopefully you can use that info to tell if it was a Cancel or a Finish.
Message 7 of 9
(3,467 Views)
Hi Darren,
I tried that and the Force Quit is TRUE for both 'Finish' and 'Cancel'.
Message 8 of 9
(3,459 Views)
I opened the reference of the NewProjectDialog.vi in spec page.vi using its path and registered for the value change events of the controls and it is working fine. Thanks Smiley Happy
Message 9 of 9
(3,456 Views)
