Project from Wizard
Can i create a project wizard like the Instrument Driver Project under the Project>>Project from Wizard in the create new dialog?
If not would i make all VIs in a project .VIT
- James
Using LV 2012 on Windows 7 64 bit
(3,004 Views)
It sounds like you want to write some LabVIEW code that actually writes LabVIEW code - that's what some of the Wizards.  Such a feature is not generally available/supported.  If you really desire doing this, you should check out the LAVA forums.
On the other hand, you could build a bit more bulky code which simply takes in all of the configuration settings that your wizard would expose, and then basically use a number of case structures behing the scenes to choose the "correct cases" for that configuration.
Best Regards,
JLS
Best,
JLS
Sixclear
(2,979 Views)
