Text string to Hex number string.
4-4-07
In my application I read a string in from a .txt file. The string consist of 8 groups of 2 digits representing hex codes. Like: 0112010208020211. I need to convert this in to hex numbers 01 12 01 02 08 02 02 11 so that I can attach a header and calculate a check sum. When I load 0112010208020211 into a string control set for hex display I get 3031 3132 3031 3032 3038 3032 3032 3131, which is ok because I can add my header and calculate the check sum in this form but how do I get it back to 01 12 01 02 08 02 02 11 form to send to the device under test?
TeBlues
(3,936 Views)
- James
Using LV 2012 on Windows 7 64 bit
(3,931 Views)
- James
(3,931 Views)
sorry my computer freaked out and posted many times
Message Edited by James R on 04-04-2007 04:45 PM
- James
(3,933 Views)
4-5-07
Thanks James R. This is just what I was looking for, it dose exactly what I need.
Thanks again
TeBlues
(3,901 Views)
