Project of clock, calendar, reminders and alarm.
Hi Jito,
It has been said before, but you need to start the project on you rown, and we will provide help on the way.
We won't do the code for you.
Have a nice day.
Message 11 of 14
(1,071 Views)
Thank you
Message 12 of 14
(1,050 Views)
Some general tips on how to proceed.
1.  What will the Front panel consist of?  What buttons/actions should be provided to the user?  Should events be created after clicking a button or after double-clicking a date (like many web-based calendars do)?  Specifying the user interactions helps to identify how sections of your code should work together (do multiple buttons require access to the same list of events/alarms?).
2.  How should the data be stored?  Options vary from array/clusters with shift registers, global variables, functional global variables (FGV), to external files (.txt, .csv, or Configuration files (.ini)).  Will the program be running 24/7, 5-10 minutes for grading, or through multiple computer power cycles?
3.  Should you use more advanced architecture?  While it may be possible to create this using a while loop and constantly checking buttons / alarms, this is an inefficient use of computer memory and it tends to result in large/messy block diagrams.  An architecture such as a State Machine or Producer/Consumer may be a worthwhile investment.
Spend some time to plan how the program will look/function before you start writing it.  Barging in without a clear direction is an easy way to get yourself stuck (which I've done plenty of times when I first started using LabVIEW).
It's quite probable that many routes/options are beyond the scope or needs of your class but could be worthwile if you forsee using LabVIEW in your future.
Message 13 of 14
(1,032 Views)
thank you !
Message 14 of 14
(1,009 Views)
