Prompt User with listbox and output array of names
I would like to create a Listbox popup where the user will select the respective rows that he needs to be tested and then disappear after pressing continue.
The attached program will become part of a larger state machine that is currently being developed.
Can you tell me how to create a listbox popup to show up until the user has made his selections?  Any help will be greatly appreciated!
hiNi.
(2,664 Views)
Use an event structure to get the row when double clicked, you can then close the diagram.
Attached is a starting point.
mcduff
(2,640 Views)
Accepted by hiNI
You can select multiple rows using ctrl-click and shift-click (with the conventional behavior). Here's one possible solution.
(Note that the subVI is set to "dialog" style).
(2,636 Views)
Hello, Thanks for your solution.
I am trying how to do the step of setting the subVI to "dialog" style.
Can you tell me how this is done?
Thanks again!
(2,589 Views)
Thanks again!
It's one of the pre-defined "VI properties ...windows appearance" settings:
(2,580 Views)
