Propagate data point to multiple consumers? I'm probably overcomplicating this.
You could change also the other part of your code, to work with arrays.
Message 11 of 13
(725 Views)
I highly recommend that you eliminate use of the dynamic data type as much as possible entirely. While it might seem easier, it can cause all sorts of problems because it attempts to adapt to the type of data it thinks you want, often in ways you don't expect.
If you post your code, we can probably help sort out your problems. It's reasonable to use either waveforms or arrays, depending on which is more convenient for your application, but you probably want to be consistent throughout (don't read some channels as waveforms and others as arrays unless there's a good reason for doing so).
Message 12 of 13
(716 Views)
Changing the code to work with arrays is a luxury I don't have time for at the moment.  Thanks for the input -- Looks like shift register wins for this particular iteration of the code.
___________________________________________________________________
Still confused after 8 years.
Message 13 of 13
(682 Views)
