Properties and Array inside Cluster
I have a complex structure of LV controls defined as a strict typedef: Array
of cluster with a number of controls inside. One of the controls inside the
cluster is a array.
On the frontpanel I display this control and I will programmatically set the
index of the array inside the cluster.
Is it possible??? How??
Hans ?hra
(2,644 Views)
I have attached an example that illustrates how to accomplish what you are trying to do. One of the key elements in getting it to work is the use of the "To More Specific Class" function.
There is some good related information available at:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/b4f437c8bf034293862569f800618197?OpenDocument
Please let me know if you have any questions.
Thanks.
Matt Kisler
Application Engineer
http://www.ni.com/ask
(2,644 Views)
