Property Node with Array As Input
I have an array, and I would like to get the unique values. Then I would like to place the unique values as input
to my numeric control. From the diagram below, the user would able to choose the following numbers:
1,2,3,5,7; since thess are the unique values
In a nutshell is it possible to place irregularly spaced numbers into a numeric control.
22469i8DC8C22AAB42EF26
If the above is not possible, can one pass the unique values to a menu ring instead
(3,545 Views)
Accepted by ade77
A numeric control only accepts a single value. You cannot have it hold multiple values.
You could set the Strings[] property of the menu ring to your list of values:
(3,541 Views)
Instead of passing the unique values to a numeric control, which you can't do, you can pass them to an ARRAY of numerics.
22479i783EDCA8989DFF9E
- tbob
Inventor of the WORM Global
(3,520 Views)
