03-13-2007 11:56 AM
I am new to LabView and am porting a previously functioning LabView application (written in version 7.something) to 8.2. There are instances of a property node which it complains about. I understand the message, however, I do not know which wire it is complaining about. I have attached a bitmap image of the screen with the block, and the error message.
If I needed to delete this field, how would I do it?
03-13-2007 03:01 PM - edited 03-13-2007 03:01 PM
You are missing the Reference output from the Open to the Property Node.
Message Edited by AndrewAlford on 03-13-2007 02:02 PM
03-13-2007 03:15 PM
03-13-2007 04:20 PM
It would appear that in earlier versions of LabView, the VI instance of this ref node worked as wired ... i.e. it defaulted to the current vi. When I tried to wire the application reference to the ref node, it caused the type to change which made all sorts of things illegal.
I ended up using a Vi reference to feed it and all was good.
As to the deprecated field, there was no suggestion as what to do. Since it worked, I am going to ignore that issue for now.
Thanks for your help!!
