Property node legend autosize problem
Hi.
I have the problem with legend autosize using property node.
I attach selected files.
About the problem:
After running the program, I change curve1 string (upper graph) (constant on the block diagram), run program again, change back curve 1 string and run program again. Legend autosize is working properly.
Then in the "other graphs" combo box (methode 1) change to "Charakterystyka + W3 +W5", run program, go back to "wyłączony" and run program again. Autosize isn't working properly. If we run program with "Stały wyprostowany" and again with "wyłączony" it will autosize legend properly.
Please look at my code, maybe u will be able to find a defect in my app.
Thank a lot.
(4,456 Views)
Hi
I would like to help with your problem, are you able to send a screen shot of the front panels showing the problem you are experiencing?
(4,364 Views)
I've solved that problem. LabVIEW remembered all legend names, even if they're not shown. Clearing all previous names solved the problem.
(4,359 Views)
Great Stuff!
Happy Coding
(4,355 Views)
