Protect acess to shared variable network
I have a network with applications on several PCs and I used variable of type network-published for communicate between them.
If somebody will do one conection with my network, because there are possibility of conection with my switch, then i can't protect my application.
I want give enable at some variables that everybody can have acess, and another one variables disable acess.
So I want share some variables of my application but not all.
Thank you in advance
(2,919 Views)
Hey,
Just use Tools>Shared Variables>Variable Manager. With Edit>Security you can grant access to computers or deny it.
BR, Christian
(2,897 Views)
Thaks Christian
I found the next link
http://zone.ni.com/devzone/cda/tut/p/id/3322
(2,879 Views)
